STM32CubeMx LTDC version 5.6.7 produce code with 1 Layer, version 6.0 produce code for 2 layers even if set 1.
Is this a bug?
Options
‎2020-11-27 4:44 AM
Open STM32H7BWorkshop2020 STM32H7B3I-DK.ioc first do not migrate, and generate code. Then migrate and generate code. Then check content of static void MX_LTDC_Init(void)
Labels:
LCD-LTDC
STM32CubeMX
STM32H7 series
Options
‎2020-12-30 5:40 AM
Hello @Community member​ ,
Normally this issue has been fixed with the 6.1.0 CubeMX version, can you please check with it ?
Thanks, Khouloud
Options
‎2021-01-07 12:01 AM
Hi, thanks for reply.
I am currently using 6.1.1 but i did not check if fixed. Just modified the produced code removing manually the second layer.
