STemWin listview problem
M Ryb
Posted on July 19, 2017 at 10:36
I have some trouble with my listview widget.
1. I can change the column width 'manually' - I mean by touch. Is there a possibility to set it fixed width? I noticed that when I change the width by this way the listview sorting doesn't work properly.
2. After change of listview cell color, the cell selection stops working - when I touch it it doesn't change the color. Do you have any idea what is the problem?
I will appreciate any help!
#listview #stemwin
Rohit  Mishra
Posted on August 16, 2017 at 07:31
Did you face this issue with Listview.
http://forum.segger.com/index.php?page=Thread&postID=15707#post15707
Rohit
Posted on August 24, 2017 at 09:48
Thank you for your help. Changing the header callback helped.
Magda
