2021-03-22 7:22 AM
I have a hexagon shape. I want to move (40,0) to (80,0), (0,0) to (40,0), (40,80) to (0,80), (80,80) to (40,80) and I want to move them back. What should be the condition? I gave a try but I couldn't see any move.
Here is my shape;
shape1.setPosition(111, 89, 80, 80);
shape1.setOrigin(0.000f, 0.000f);
shape1.setScale(1.000f, 1.000f);
shape1.setAngle(0.000f);
shape1Painter.setColor(touchgfx::Color::getColorFrom24BitRGB(122, 51, 51));
shape1.setPainter(shape1Painter);
const touchgfx::AbstractShape::ShapePoint<float> shape1Points[6] = { { 80.000f, 40.000f }, { 80.000f, 80.000f }, { 40.000f, 80.000f }, { 0.000f, 40.000f }, { 0.000f, 0.000f }, { 40.000f, 0.000f } };
shape1.setShape(shape1Points);and the animation in handleTickEvent ;
CWRUtil::Q5 currentX, currentY;
shape1.invalidate();
shape1.getCornerX(5) = currentX;
shape1.getCornerY(5) = currentY;
if (currentX < shape1.getCornerX(1))
shapeXChangeFactor = CWRUtil::Q5(80);
else if (currentX == shape1.getCornerX(1))
shapeXChangeFactor = CWRUtil::Q5(-80);
currentX = currentX + shapeXChangeFactor;
shape1.setCorner(4, currentX, currentY);
2021-03-23 5:25 PM
Hi Ezgi,
There are potentially 2 issues in your code.
* Sets one of the points (a corner) of the shape in CWRUtil::Q5 format.
* @param i Zero-based index of the corner.
* @param x The x coordinate in CWRUtil::Q5 format.
* @param y The y coordinate in CWRUtil::Q5 format.
* @see updateAbstractShapeCache
* @note Remember to call updateAbstractShapeCache() after calling setCorner one or more times,
* to make sure that the cached outline of the shape is correct.
virtual void setCorner(int i, CWRUtil::Q5 x, CWRUtil::Q5 y) = 0;So here is a code example you can base yourself on :
void Screen1View::changeShape()
if(changed)
//go back to normal
changed = false;
shape1.setCorner(5, CWRUtil::toQ5<float>(40.000f), CWRUtil::toQ5<float>(0.000f));
else
//do the change
shape1.setCorner(5, CWRUtil::toQ5<float>(80.000f), CWRUtil::toQ5<float>(0.000f));
changed = true;
shape1.updateAbstractShapeCache();
}When your question is answered, please close this topic by choosing Select as Best.
/Alexandre
2021-03-22 9:57 AM
I mean Shapes not use invalidate for change. And you dont show code where you create shape1 and add to screen...
2021-03-22 11:29 PM
The shape is declared in Base and handleTickEvent is in View.cpp. When I was writing the handleTickEvent, I took a look at the Line and Circle example.
2021-03-23 5:25 PM
Hi Ezgi,
if(changed)
//go back to normal
changed = false;
else
//do the change
changed = true;
/Alexandre
