ScrollWhell - I can't select first item
EEuge
I scroll ScrollWheel to first item, but when I release finger, scrolwheel scrolls to second item automatically.
How to solve?
Alexandre RENOUX
Principal
Hello EEuge,
Could you try to see if the solution of this post helps you ?
If not, could you elaborate your issue ? (Setup info, Video, UI code, etc.) Does it happen also on the simulator ?
/Alexandre
