QSPI
heyo
What to do if I do not want to load my images to QSPI flash every time I upload the code?
_EFrie
Probably add it to your .noload section
_EFrie
JTP1
Lead
Hello
Hmm if you want to remove ext_flash section, you can use arm-none-eabi-objcopy- command.
like:
arm-none-eabi-objcopy.exe --remove-section=ExtFlashSection "yourFilename.elf" "IntFlash.elf"
and place this to the post-build command.
https://community.st.com/s/question/0D53W00000Y3qptSAB/is-it-possible-to-decice-the-memory-area-to-download-on-uc-and-qspi
I just want that every time don't upload all bitmaps images to my QSPI because it takes about 2-3 min. Maybe there is simple way to comment something in code and don't upload bitmaps. And when I need to renew my bitmaps I could do it in simple way :D
