QR Code Feature issue in TouchGFX 4.24
akdou
Visitor
Hello ,
i am working for the first time on TouchGfx and learning step by step some basics about it . I currently encountred a problem with QR Code Feature . If i put an URL Link longer than 17 characters ,it wont be shown after i run the simulation .
Is it a commun Problem ?
LouisB
Hello @akdou ,
QR codes data capacity depends on the parameters you set, refer to the documentation : https://support.touchgfx.com/docs/development/ui-development/ui-components/images/qr-code .
And to the QR codes specs here https://www.qrcode.com/en/about/version.html .
BR,
Louis BOUDO
3 REPLIES 3
LouisB
Hello @akdou ,
BR,
Louis BOUDO
Hello @LouisB ,
Thank you so much that was really helpful !
best Regards
LouisB
You are welcome, glad that it helped you, don't forget to chose a best answer so others can find the solution easier.
BR,
Louis BOUDO
