QR Code Feature issue in TouchGFX 4.24
‎2024-10-17 11:59 PM - last edited on ‎2024-10-18 1:47 AM by mƎALLEm
Hello ,
i am working for the first time on TouchGfx and learning step by step some basics about it . I currently encountred a problem with QR Code Feature . If i put an URL Link longer than 17 characters ,it wont be shown after i run the simulation .
Is it a commun Problem ?
TouchGFX
‎2024-10-18 2:25 AM
Hello @akdou ,
QR codes data capacity depends on the parameters you set, refer to the documentation : https://support.touchgfx.com/docs/development/ui-development/ui-components/images/qr-code .
And to the QR codes specs here https://www.qrcode.com/en/about/version.html .
BR,
‎2024-10-18 2:25 AM
Hello @akdou ,
BR,
‎2024-10-18 3:16 AM
‎2024-10-18 3:19 AM
You are welcome, glad that it helped you, don't forget to chose a best answer so others can find the solution easier.
BR,
