Problem with CRC module on touchgfx in stm32h7 ?
‎2021-04-09 1:57 AM
Hello, I'm working with the STM32H7B3I-DK.
Info:
1- STM32H7B3I-DK (STM32H7B3LIH6QU)
2-STM32CUBEIDE rev: 1.6.1
3- TouchGfx rev: 4.16.1
I want to use the CRC module for data verification (16 bit).
Problem:
when I use the CRC default version everything works fine
hcrc.Instance = CRC;
hcrc.Init.DefaultPolynomialUse = DEFAULT_POLYNOMIAL_ENABLE;
hcrc.Init.DefaultInitValueUse = DEFAULT_INIT_VALUE_ENABLE;
hcrc.Init.InputDataInversionMode = CRC_INPUTDATA_INVERSION_NONE;
hcrc.Init.OutputDataInversionMode = CRC_OUTPUTDATA_INVERSION_DISABLE;
hcrc.InputDataFormat = CRC_INPUTDATA_FORMAT_BYTES;
if (HAL_CRC_Init(&hcrc) != HAL_OK)
Error_Handler();
But when I use this version of CRC to calculate my crc on my data, there is a problem with touchgfx (touchgfx_init)
hcrc.Init.DefaultPolynomialUse = DEFAULT_POLYNOMIAL_DISABLE;
hcrc.Init.GeneratingPolynomial = CRC_POLYNOMIAL_VALUE;
hcrc.Init.CRCLength = CRC_POLYLENGTH_16B;
Error_Handler();
Error :
in touchgfx_init function
FrontendHeap::getInstance()
touchgfx::Screen::draw()
"<signal handler called>() at 0xffffffe9"
HardFault_Handler
I do not understand why.
Is there a problem with touchgfx and CRC module?
Thanks in advanced to all your replies
CRC
STM32H7 series
TouchGFX
‎2021-04-09 3:07 AM
It is used to authenticate STM32 hardware. You should reset the CRC peripheral at a bus level​ once you are done with it.
‎2021-04-09 5:05 AM
thank you for the answer
This authentication is done only at startup ?
This means that I have to reset the CRC peripheral each time I use it.
‎2021-04-09 11:10 AM
I'd hope its a once and done thing at initialization, but this isn't my circus...
You could perhaps test the hypothesis, or turn the clock off occasionally and see if it is used again.
‎2021-11-04 4:01 AM
I have the exact problem: with default CRC poly all is ok, but if I try to change the poly, the execution go in hard fault after MX_TouchGFX_Init().
Is there a solution?
‎2021-11-04 4:42 AM
I think I have resolve the problem: I leave the default poly and, after all initializations, I re-init the CRC peripheral. Now it work
‎2021-11-04 8:44 AM
Patch the libraries/object...
‎2024-03-08 2:41 PM
+1
Same for me!
Jyl
