Pressed button image
heyo
Senior
Is it possible to use bigger pressed button image than released button image? How can I achieve it?0693W00000UnwIaQAJ.png
15 REPLIES 15
Yes that's normal, so you'll need to play with these functions now :
    if (button1.getPressedState() == true)           // to know if we pressed the button
        container1.setWidth(container1NewWidth);             // change the container width
        container1.setHeight(container1NewHeight);             // change the container height
        button1.setX(button1NewXPosition);             // change the button X position to display the area you want to show
        button1.setY(button1NewYPosition);               // change the button Y position to display the area you want to show
        container1.invalidate();
        button1.invalidate();
/Osman
Osman SOYKURT
OK! Ill try it. Thank you again.
heyo
Senior
Hello @Osman SOYKURT​ . I created virtual function which calls when button is pressed and then changes containers height but nothing happens and I am sure that it fulfils function : container1.setHeight(container1NewHeight); Do you have any suggestions? Thank you.
I do like this and changes only button position : 0693W00000Uo7YtQAJ.png
Hello heyo,
Do you use invalidate() function afterwards?
/Osman
Osman SOYKURT
