parallel processing using ili9488 display and microcontroller
‎2024-09-18 9:51 PM
‎2024-09-23 4:08 AM
yes
‎2024-09-23 4:24 AM
I am not sure how to help you as I don't know what you want to do exactly, also it doesn't seems to be related to TouchGFX.
But I found some videos that could help you:
- ST guide on how to generate sin wave
- Controller's tech's guide on how to generate sin wave and see it on ili screen
Software engineer at ST (TouchGFX)
‎2024-09-30 7:33 AM
Hello @Sharan ,
Were you able to move forward on your issue?
‎2024-10-02 10:25 PM
hi i am working on stm32mp157d-dk1 now so now i will be generating sine wave using the mpu instead of microcontroller and can we access the adc and dac using arm cortex a7 and if possible how to do it?
‎2024-10-03 4:14 AM
Hello @Sharan ,
There are many ways to generate a sin wave.
You could loop through a lookup table to periodically update the value of your DAC.
You could use the math.h library to use a sin wave in TouchGFX.
Etc.
If you have another question related to TouchGFX, don't hesitate to ask it! :smiling_face_with_smiling_eyes:
‎2024-10-03 4:45 AM
Continued:
- « Previous
- 1
- 2
- Next »
