â2019-12-25 01:30 AM
â2020-01-19 11:21 AM
by google search i found this link but it is empty and show "oops":D
â2020-01-20 02:33 AM
The Link is taken down, but i just shared it with someone else - We're doing a rework on the current doc and will move from zendesk shortly.
How were your efforts in vain? You should be able to compare how our FreeRTOS oswrappers are made and do it in Keil RTX. We've done it ourselves before for customers for Keil, but i don't think i have that oswrapper lying around anymore. I'll check.
â2020-01-20 07:21 AM
hello Martin
thank you for above link
i have problem for redefine RTX Semaphore instead FreeRTOS Semaphores.
previously i use emwin and i config "GUI_X_OS.c" file incorrect for a long time and i had many problems.
that was a very bad experience:loudly_crying_face:. after find true config for "GUI_X_OS.c" all problem solvedđ
If you publish it, it will be safe and secure.
thank you
