2024-11-07 07:14 AM
Process Explorer is showing a number of TouchGFXDesigner processes as running even though all instances of it have been closed (there are no windows visible).
I found this when I tried to delete and folder and that failed with an "in use" message - Resource Monitor showed this use was by the orphaned TouchGFXDesigner processes.
I am using version 4.23.1 under Windows 11.
2024-11-07 08:42 AM
"We have fixed this issue in the latest version of TouchGFX (4.23.2). "
2024-11-07 07:20 AM
Hello @CTapp.1 ,
I will come back to you tomorrow morning!
2024-11-07 08:42 AM
2024-11-07 09:05 AM
Thanks, I'll go grab the update...
