Looking for resource or steps to get started LCD project using STM32H753 board?
‎2020-09-11 6:38 AM
I am working on a custom LCD project using STM32h753 Eval 2. Currently i dont have a tremendous knowledge in LCD. I tried to follow the example codes and some tutorial but not able to make it work. can you suggest any resource or steps to get started?
i am using a custom 1024*768 LCD. This LCD receives signals through LCDT. the config given by the manufacturer is
#define PanelHSyncWidth 43
#define PanelHSyncBackPorch 29
#define PanelVSyncWidth 6
#define PanelVSyncBackPorch 34
#define PanelHStart (PanelHSyncWidth+PanelHSyncBackPorch)
#define PanelVStart (PanelVSyncWidth+PanelVSyncBackPorch)
#define PanelWidth 1024
#define PanelHeight 768
#define PanelHTotal 1344
#define PanelVTotal 806
#define PanelMaxHTotal 2048
#define PanelMinHTotal 1120
#define PanelMaxVTotal 1024
#define PanelMinVTotal 776
#define PanelDCLK 65
#define PanelMaxDCLK 71
#define PanelMinDCLK 52
when i try to modify the example code with these data, i was able to get the LCD ON but did not get the expected result.
this is what i get when i change the sync config and clock. what are all the possible reasons where i am messing things up?
thanks in advance for providing your valuable time.:beaming_face_with_smiling_eyes:
LCD-LTDC
STM32H7 Series
‎2020-10-12 2:05 AM
Thank you. it seems like the problem was with the custom LCD. its solved now.
‎2020-09-14 3:28 AM
Hello @UPa.1​ ,
Have a look on this AN4861 Application note LCD-TFT display controller (LTDC) on STM32 MCUs, this may helps you to configure your project.
Best Regards
Imen
Imen
‎2020-10-12 2:05 AM
