2020-05-29 02:50 AM
Is there any SSD1963 driver source compatible with STM32F030RCT6 micro-controller?
2020-05-29 03:32 AM
> Is it possible to integrate SSD1963 5.1 inch LCD with the STM32F030RCT6 controller?
Yes, the SSD1963 provides a built-inframebuffer, so there's no particular requirement on the mcu's timing. You would need to bit-bang the interface and changes on the screen will be relatively slow.
You mean, something you'd just take and use? Most probably no. Read the SSD196 datasheet and design your interface accordingly. You can get inspired in the various arduino-targeted software on the web, or e.g. see this.
