I interfaced Camera to the STM 32f746G . i used pixelData widget to show the camera feed and created GUI above it. the problem is that i have tearing when i am using GUI on top of the pixel widget. I think its synchronization problem
MSale
13 REPLIES 13
MSale
@Martin KJELDSEN​
Hi Martin,
I solved the problem and its working fine now bottom layer live video at 30fps without tearing and top layer the gui. thanks for your help really appreciated it.
Mahmoud
Glad to hear that. How did you end up solving it?
/Martin
MSale
@Martin KJELDSEN​
I made touchgfx update the 2 layers instead of 1.
i have another issue which is that i want to display the live video with alpha = 255 but for the widgets its not possible because it will override the live video. is there way to not blend the whole top layer, only the widgets
can I ask how to config 2 layer LTDC by useing CUBEMX for TOUCHGFX? CUBEMX warning me touchgfx can‘t use 2 layer config
