2023-04-23 03:24 AM - edited 2023-11-20 07:21 AM
2023-04-24 12:48 AM - edited 2023-11-20 07:22 AM
Hello @Community member and welcome to the Community
Please try Checking the Display Colors to make sure that your display colors configuration is correct.
You can also check your LTDC configuration from the AN4861 (LTDC parameter/layer settings, LTDC clocks and timings configuration...).
If my answer helped you, please select it as Best so that this thread will marked as solved.
Imen
