How to make a theme like windows in PC?
Breeze1
I want to chang the theme in our device, like windows which has bright or dark theme.How to do?
Alexandre RENOUX
Principal
You could save a value in the Model like uint8_t theme = 0 (if bright theme) or 1 (if dark theme).
When you enter a screen you first check this value and load the assets and colors accordingly.
/Alexandre
Thanks for your answer.
@Alexandre RENOUX​ could you describe how to do this to invert a 1 bit lcd?
