2021-11-12 04:54 AM
2021-11-15 08:53 AM
Better explai your question in normal TouchGFX is implemented with RTOS and your c code is run as next thread .
Then you hav etwo ways howto send values to GUI.
if (tickCounter % 2 == 0 && lastvalue != SharedStruct.newvalue) {
imageProgressL.setValue(SharedStruct.newvalue);
lastvalue = SharedStruct.newvalue;
2021-11-12 05:37 AM
Why c files, GFX is cpp. Or better is your project managed only in designer or you use IDE ?
In normal IDE is used for custom projects and all files need be added to for example core or gui folders, not to in name generated files/folders.
Then project refresh show new files and manage make.
If only designer is used , is required manual edit makefiles usw... beter is use existed files only.
2021-11-15 03:08 AM
Hi @MM..1 Thanks for your reply.
I have my sensor application code in .c. I want to show the sensor values on display. My working sensor application is in STM32CubeIDE and getting the values on Tera Term (UART). So, how to integrate Touch GFX generated code to my sensor code and show the output on display?
2021-11-15 08:53 AM
