2019-08-28 01:02 AM
If I generate a slider in a screen in the Designer 4.10.0, I get the additional interaction selections like "Slider value changed" etc. If I generate a scrollable container or a scroll wheel, I get no such possibility to react to changes. How can I add appropriate interactions in this case?
2019-08-28 05:10 AM
Hi @stst9185,
What is it exactly that you would like to have notifications for? It may be that we could add some more interactions for other widgets. The reason for "value changed" in the case of the slider is because it's directly inherent in its nature to adjust the slider position.
/Martin
2019-08-29 04:40 AM
2019-08-29 06:06 AM
Thanks for the feedback, Hermann. I'll try to review the current state of the container based widgets for scroll, etc and check if we already have a task for this in the backlog.
/Martin
