‎2020-08-03 05:41 AM
I am using the GUI on the top layer above live video and i must insert some box behind the widgets otherwise i got noise in the background on the top layer
‎2020-08-03 07:00 AM
@Alexandre RENOUX​
By using color keying for the top layer
Mahmoud
‎2020-08-03 06:01 AM
Problem was solved
‎2020-08-03 06:57 AM
Good that you were able to solve it.
Could you explain how you solved it ? It might come useful for other people.
Thank you in advance 🙂
/Alexandre
@Alexandre RENOUX​
Mahmoud
