How can I adapt the OSPI example made with MX25LM51245GMI00 to QSPI.
Freedom_Neo
I am using below development tools
MCU: STM32H7B3IIT6
IDE: STM32CubeIDE Version: 1.8.0
GUI: TouchGFX Version: 4.18.1
SDRAM: IS45S16800F-7CTLA1-TR
FLASH: MX25LM51245GMI00
I work on external FLASH. Because I have few pins I use QSPI, I am not use OSPI. STM32H7B3-DK develeopment board use OSPI it connected MX25U51245GMI00. There is OSPI example but dont have QSPI. How can I adapt the OSPI example made with MX25U51245GMI00 to QSPI.
Hello @Osman SOYKURT​
I gave up on it. Continuing with the next post. Ignore this.
3 REPLIES 3
Osman SOYKURT
Hello Freedom_Neo,
Have you found a solution to your issue ? I saw your other post about using Octo SPI, so I'm wondering if you still need answer for this one. If yes, I invite you to add more tags to your post (STM32 MCUs or STM32H7 maybe).
/Osman
Osman SOYKURT
Ok, can you close this post then please ?
/Osman
Osman SOYKURT
