Graph data not showing
Thomas8607
Hello.
I would use a static graph to display data. In the handletickevent function, I update the addDataPoint(x data, y data) function for the given page, but nothing appears on the graph, the scale is fine, but no line or change in the x direction can be seen on the display. I am currently using the tickcounter++ variable value for X data, which also increases in debug. For X data, I entered 0min, 200max data in the touchgfx program. I also tried the dynamic graph.
Thanks if anyone can help.
Good, Please note that just clearing the static graph doesnt reset the horizontal plotting. You must also reset X coordinate value and start increasing it again from 0 to 200 (if your X range is 0-200).
If you need constantly scrolling curve, then dynamic graph is right choice. Select scroll as dynamic behavior:
then just simply add points like
	dynamicGraph1.addDataPoint(some_value);
and graph-widget will place it to first free position (and also scrolls the curve if it is full).
So with dynamic graph you dont have to worry about X values. Naturally using dynamicGraph requires that the x interval of the data points is constant, otherwise the graph will be distorted in the direction of the X-axis.
Br JTP
26 REPLIES 26
LouisB
Hello @Thomas8607 and welcome to the TouchGFX community !
Can you post your code ?
Louis BOUDO
Hello LouisB,
Here is my screen cpp(tickCounter declared in hpp protect) :
LiveDataScreenView::LiveDataScreenView()
void LiveDataScreenView::setupScreen()
    LiveDataScreenViewBase::setupScreen();
    DisplayValues.ActiveScreenNumber = 3;
    tickCounter = 0;
	graph1.clear();
	if(SettingsValues.RadioButtonSelectedItem == 1)
		graph1.setGraphRangeY(0, 300);
		graph1.setScaleY(1);
		graph1MajorYAxisGrid.setInterval(10);
		graph1MajorYAxisGrid.setScale(1);
		graph1MajorYAxisLabel.setInterval(20);
		graph1MajorYAxisLabel.setLabelDecimals(0);
		graph1MajorYAxisLabel.setScale(1);
	else if(SettingsValues.RadioButtonSelectedItem == 2)
		graph1.setGraphRangeY(0, 6000);
		graph1MajorYAxisGrid.setInterval(200);
		graph1MajorYAxisLabel.setInterval(1000);
	else if(SettingsValues.RadioButtonSelectedItem == 3)
		graph1.setGraphRangeY(-4, 4);
		graph1.setScaleY(10);
		graph1MajorYAxisGrid.setInterval(1);
		graph1MajorYAxisGrid.setScale(10);
		graph1MajorYAxisLabel.setInterval(2);
		graph1MajorYAxisLabel.setLabelDecimals(1);
		graph1MajorYAxisLabel.setScale(10);
	else if(SettingsValues.RadioButtonSelectedItem == 4)
		graph1.setGraphRangeY(0, 9000);
		graph1MajorYAxisGrid.setInterval(100);
	else if(SettingsValues.RadioButtonSelectedItem == 5)
		graph1.setGraphRangeY(0, 4);
		graph1MajorYAxisLabel.setInterval(1);
	else if(SettingsValues.RadioButtonSelectedItem == 6)
	else if(SettingsValues.RadioButtonSelectedItem == 7)
		graph1.setGraphRangeY(0, 250);
		graph1MajorYAxisGrid.setInterval(5);
		graph1MajorYAxisLabel.setInterval(25);
	else if(SettingsValues.RadioButtonSelectedItem == 8)
void LiveDataScreenView::tearDownScreen()
    LiveDataScreenViewBase::tearDownScreen();
void LiveDataScreenView::handleTickEvent()
	tickCounter++;
	HardwareValues.TickCounter = tickCounter; // for debugging
	if (tickCounter % 2 == 0)	// Insert each second tick
			graph1.addDataPoint(tickCounter, 20/*DisplayValues.Speed*/);
			graph1.addDataPoint(tickCounter, DisplayValues.Rpm);
			graph1.addDataPoint((float)tickCounter, DisplayValues.Acceleration);
			graph1.addDataPoint(tickCounter, (uint16_t)DisplayValues.TravelledMeter);
			graph1.addDataPoint((float)tickCounter, DisplayValues.ImapPressure);
			graph1.addDataPoint((float)tickCounter, DisplayValues.EmapPressure);
			graph1.addDataPoint(tickCounter, DisplayValues.IntakeTemp);
			graph1.addDataPoint(tickCounter, DisplayValues.CoolantTemp);
		graph1.invalidate();
	if(DisplayValues.BootScreenActivate == 1   && DisplayValues.ActiveScreenNumber != 0) {
		static_cast<FrontendApplication*>(Application::getInstance())->gotoBootScreenScreenSlideTransitionEast();
void LiveDataScreenView::RadioButtonSet(uint16_t itemSel)
	switch(itemSel)
	case 1: radioButtonGroup1.setSelected(radioButton1);
	break;
	case 2: radioButtonGroup1.setSelected(radioButton2);
	break;
	case 3: radioButtonGroup1.setSelected(radioButton3);
	break;
	case 4: radioButtonGroup1.setSelected(radioButton4);
	break;
	case 5: radioButtonGroup1.setSelected(radioButton5);
	break;
	case 6: radioButtonGroup1.setSelected(radioButton6);
	break;
	case 7: radioButtonGroup1.setSelected(radioButton7);
	break;
	case 8: radioButtonGroup1.setSelected(radioButton8);
	break;
void LiveDataScreenView::radioButton1Selected()
	SettingsValues.RadioButtonSelectedItem = 1;
	ExtEEPROM.writeToEEPROM(RadioButtonSelectedItem_EEPROMADDRESS, SettingsValues.RadioButtonSelectedItem);
	graph1.clear();
void LiveDataScreenView::radioButton2Selected()
	SettingsValues.RadioButtonSelectedItem = 2;
	graph1.clear();
void LiveDataScreenView::radioButton3Selected()
	SettingsValues.RadioButtonSelectedItem = 3;
	graph1.clear();
void LiveDataScreenView::radioButton4Selected()
	SettingsValues.RadioButtonSelectedItem = 4;
	graph1.clear();
void LiveDataScreenView::radioButton5Selected()
	SettingsValues.RadioButtonSelectedItem = 5;
	graph1.clear();
void LiveDataScreenView::radioButton6Selected()
	SettingsValues.RadioButtonSelectedItem = 6;
	graph1.clear();
void LiveDataScreenView::radioButton7Selected()
	SettingsValues.RadioButtonSelectedItem = 7;
	graph1.clear();
void LiveDataScreenView::radioButton8Selected()
	SettingsValues.RadioButtonSelectedItem = 8;
	graph1.clear();
Thank you!
I recorded the issue. I don't see the line and the x axis doesn't move.
Dashboard graph
Thank you!
Check in debuger if your handletick func is called ...
I tried it. The tickcounter increments
Try break on next ifs or change
if ((tickCounter % 2) == 0)
This is working
Hello Thomas
Maybe slow down process bit, now its adding points maybe 30 times / sec. Also divide counter when using as x coordinate, in your version x- value is running out of screen in few seconds, I guess.
tickCounter++;
if (tickCounter % 60 == 0)	// Insert each second tick
		graph1.addDataPoint(tickCounter/60, 20/*DisplayValues.Speed*/);
And also clear tickCounter when radiobutton is pressed.
Basically your simplified tickHandler- code seems to work in 4.23.2 simulator and also STM32U5DK2 target.
Br JTP
I will try it with == 60, if i change radiobutton then i clrear the graph (is is good)
Thank you!
