Gfx Designer - add an option to exclude a screen from build/code generation
ferro
Lead
Hi Gfx Team,
Could you consider adding an option to screen item in Canvas to exclude a screen from build/code generation
Ferro
Hello @ferro ,
Thank you so much for the suggestion. We will definitely consider the idea, and probably implement it in the future releases.
Much appreciated!
Mohammad MORADI
Hello @ferro ,
Much appreciated!
Mohammad MORADI
