Gfx Designer - add an option to exclude a screen from build/code generation
Options
‎2023-11-27 9:26 AM
Hi Gfx Team,
Could you consider adding an option to screen item in Canvas to exclude a screen from build/code generation
Ferro
Labels:
TouchGFX
TouchGFX Designer
Options
‎2024-02-06 7:03 AM
Hello @ferro ,
Thank you so much for the suggestion. We will definitely consider the idea, and probably implement it in the future releases.
Much appreciated!
Mohammad MORADI
1 REPLY 1
Options
‎2024-02-06 7:03 AM
Hello @ferro ,
Much appreciated!
Mohammad MORADI
