errors in tutorial 4
JohnSkeldon
here i am again , having trouble.. I'm part way though tutorial 4 ( Tutorial 4: Creating a Scroll Wheel with Custom Behavior | TouchGFX Documentation) . it gives 2 pieces of code to put in and then says when u run the simulator you'll get this image of scroll wheel with icons changing..
I get a load of errors.  I have very little c++ knowledge i'm used to embedded c.  So i do have a bit of a learning curve but i feel as if there is a step missing or a piece of code missing..
Compiling generated/gui_generated/src/containers/MenuElementBase.cpp Compiling generated/gui_generated/src/screen1_screen/Screen1ViewBase.cpp Compiling generated/gui_generated/src/common/FrontendApplicationBase.cpp Compiling generated/simulator/src/video/SoftwareMJPEGDecoder.cpp In file included from generated/gui_generated/include/gui_generated/screen1_screen/Screen1ViewBase.hpp:13:0, from gui/include/gui/screen1_screen/Screen1View.hpp:4, from generated/gui_generated/include/gui_generated/common/FrontendHeapBase.hpp:15, from gui/include/gui/common/FrontendHeap.hpp:4, from generated/gui_generated/src/common/FrontendApplicationBase.cpp:6: gui/include/gui/containers/MenuElement.hpp: In member function 'void MenuElement::setNumber(int)': gui/include/gui/containers/MenuElement.hpp:21:9: error: 'icon' was not declared in this scope icon.setBitmap(Bitmap(BITMAP_ICON00_ID)); ^~~~ In file included from generated/gui_generated/include/gui_generated/screen1_screen/Screen1ViewBase.hpp:13:0, from gui/include/gui/screen1_screen/Screen1View.hpp:4, from gui/src/screen1_screen/Screen1Presenter.cpp:1: gui/include/gui/containers/MenuElement.hpp: In member function 'void MenuElement::setNumber(int)': gui/include/gui/containers/MenuElement.hpp:21:9: error: 'icon' was not declared in this scope icon.setBitmap(Bitmap(BITMAP_ICON00_ID)); ^~~~ In file included from generated/gui_generated/include/gui_generated/screen1_screen/Screen1ViewBase.hpp:13:0, from gui/include/gui/screen1_screen/Screen1View.hpp:4, from gui/src/screen1_screen/Screen1View.cpp:1: gui/include/gui/containers/MenuElement.hpp: In member function 'void MenuElement::setNumber(int)': gui/include/gui/containers/MenuElement.hpp:21:9: error: 'icon' was not declared in this scope icon.setBitmap(Bitmap(BITMAP_ICON00_ID)); ^~~~ gui/include/gui/containers/MenuElement.hpp:21:9: note: suggested alternative: 'ico2' icon.setBitmap(Bitmap(BITMAP_ICON00_ID)); ^~~~ ico2 gui/include/gui/containers/MenuElement.hpp:21:9: note: suggested alternative: 'ico2' icon.setBitmap(Bitmap(BITMAP_ICON00_ID)); ^~~~ ico2 gui/include/gui/containers/MenuElement.hpp:21:9: note: suggested alternative: 'ico2' icon.setBitmap(Bitmap(BITMAP_ICON00_ID)); ^~~~ ico2 In file included from gui/src/containers/MenuElement.cpp:1:0: gui/include/gui/containers/MenuElement.hpp: In member function 'void MenuElement::setNumber(int)': gui/include/gui/containers/MenuElement.hpp:21:9: error: 'icon' was not declared in this scope icon.setBitmap(Bitmap(BITMAP_ICON00_ID)); ^~~~ gui/include/gui/containers/MenuElement.hpp:21:9: note: suggested alternative: 'ico2' icon.setBitmap(Bitmap(BITMAP_ICON00_ID)); ^~~~ ico2 make[2]: *** [build/MINGW32_NT-6.2/gui/src/screen1_screen/Screen1View.o] Error 1 generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/gui/src/screen1_screen/Screen1View.o' failed make[2]: *** Waiting for unfinished jobs.... generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/gui/src/screen1_screen/Screen1Presenter.o' failed make[2]: *** [build/MINGW32_NT-6.2/gui/src/screen1_screen/Screen1Presenter.o] Error 1 In file included from generated/gui_generated/include/gui_generated/screen1_screen/Screen1ViewBase.hpp:13:0, from generated/gui_generated/src/screen1_screen/Screen1ViewBase.cpp:4: gui/include/gui/containers/MenuElement.hpp: In member function 'void MenuElement::setNumber(int)': gui/include/gui/containers/MenuElement.hpp:21:9: error: 'icon' was not declared in this scope icon.setBitmap(Bitmap(BITMAP_ICON00_ID)); ^~~~ gui/include/gui/containers/MenuElement.hpp:21:9: note: suggested alternative: 'ico2' icon.setBitmap(Bitmap(BITMAP_ICON00_ID)); ^~~~ ico2 generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/gui/src/containers/MenuElement.o' failed make[2]: *** [build/MINGW32_NT-6.2/gui/src/containers/MenuElement.o] Error 1 generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/generated/gui_generated/src/common/FrontendApplicationBase.o' failed make[2]: *** [build/MINGW32_NT-6.2/generated/gui_generated/src/common/FrontendApplicationBase.o] Error 1 make[2]: *** [build/MINGW32_NT-6.2/generated/gui_generated/src/screen1_screen/Screen1ViewBase.o] Error 1 generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/generated/gui_generated/src/screen1_screen/Screen1ViewBase.o' failed generated/simulator/gcc/Makefile:155: recipe for target 'generate_assets' failed make[1]: *** [generate_assets] Error 2 simulator/gcc/Makefile:32: recipe for target 'all' failed make: *** [all] Error 2 Failed Failed
View more
JohnSkeldon
FOUND IT !!
i didnt name the icon properly. first part now compiles :)
3 REPLIES 3
JohnSkeldon
FOUND IT !!
If that's resolved the issue, please mark it as the solution:
https://community.st.com/t5/community-guidelines/help-others-to-solve-their-issues/ta-p/575256
done
