2019-04-21 06:57 AM
I am using Touch GFX on my hardware (STM32F429).
When I create a text area and change the name of text,i encounter error that say "error during code generation" then opens a window that say" ZIP entry size is too large"
It was working better before but It does not work officiantly now.
could you please help me to solve this problems?
thanks in advance.
2019-10-12 12:48 AM
@Hhesa
hello hojat, i had this problem now and i fix it
try change default language format to english from here:
Control Panel > Region > Format Tab > Format dropdown list
and restart PC, then create new project.
the error should be gone
i think you setting this option to persian because you had persian name, i am iranian too
2019-10-12 03:47 AM
I made these adjustments and the problem was resolved.
Thank you very much for your help.
