Dynamically generate and display QR code
‎2022-11-15 8:06 AM
I am using 4.16.1 TouchGFX designer tool. Is it possible to generate QR code for a given string and PIN code in run time and display? Please advice.
TouchGFX
‎2022-11-15 8:12 AM
‎2022-11-15 8:22 AM
I have used https://github.com/ricmoo/QRCode library.
Made a simple wrapper class QRCode.cpp
#include <gui/widgets/qrcode/QRCode.hpp>
#include <gui/widgets/qrcode/qrcode.h>
#include <stdlib.h>
QR::QR( const char * text )
qrcode = new QRCode();
qrcodeData = (uint8_t *)malloc( qrcode_getBufferSize(1) );
qrcode_initText( qrcode, qrcodeData, 1, 0, text );
QR::~QR()
free( qrcodeData );
delete qrcode;
bool QR::at(uint16_t x, uint16_t y) const
return qrcode_getModule( qrcode, x, y );
uint16_t QR::getWidth() const
return qrcode->size;
uint16_t QR::getHeight() const
and a custom widget QRCodeWidget.cpp
#include <gui/widgets/qrcode/QRCodeWidget.hpp>
#include <touchgfx/hal/HAL.hpp>
QRCodeWidget::QRCodeWidget() :
code(0),
scale(1)
void QRCodeWidget::setQRCode(QR *qrCode)
code = qrCode;
updateSize();
void QRCodeWidget::draw(const touchgfx::Rect& invalidatedArea) const
if(!code)
return;
touchgfx::Rect absolute = getAbsoluteRect();
uint16_t *framebuffer = touchgfx::HAL::getInstance()->lockFrameBuffer();
for(int y = invalidatedArea.y; y < invalidatedArea.bottom(); y++)
for(int x = invalidatedArea.x; x < invalidatedArea.right(); x++)
int offset=0;
switch(touchgfx::HAL::DISPLAY_ROTATION)
case touchgfx::rotate0:
offset = absolute.x + x + (absolute.y + y) * touchgfx::HAL::DISPLAY_WIDTH;
break;
case touchgfx::rotate90:
offset = (touchgfx::HAL::DISPLAY_WIDTH-(absolute.x + x)-1) * touchgfx::HAL::DISPLAY_HEIGHT
+ (absolute.y + y);
break;
framebuffer[offset] = code->at(x / scale, y / scale) ? 0x0000 : 0xffff;
touchgfx::HAL::getInstance()->unlockFrameBuffer();
touchgfx::Rect QRCodeWidget::getSolidRect() const
return touchgfx::Rect(0,0,getWidth(), getHeight());
void QRCodeWidget::setScale(uint8_t s)
scale = s;
updateSize();
void QRCodeWidget::updateSize()
if(code)
setWidth(code->getWidth() * scale);
setHeight(code->getHeight() * scale);
Using is quite straightforward:
#include <gui/common/QrCodeWidget.hpp>
#include <gui/model/QrCode.hpp>
QRCodeWidget qrCode;
QR *code;
char string[50];
sprintf( string, "http://iwtm.com" );
code = new QR( string );
qrCode.setXY(10,20);
qrCode.setQRCode(code);
qrCode.setScale(8);
add(qrCode);
‎2022-11-15 9:17 AM
Thank you for your reply. I appreciate it. Just so I understand it better, would you mind sharing QrCodeWidget.hpp and QrCode.hpp too please.
‎2022-11-15 9:22 AM
QRCode.hpp
#ifndef QR_CODE_HPP
#define QR_CODE_HPP
#include <touchgfx/hal/Types.hpp>
#include "qrcode.h"
* @class QRCode
* @brief An interface for getting the value of a qr code at a particular x,y position
* This implementation generates random values for the different x,y coordinates.
* A real qr code will probably save the qr code values in an array like structure and report these instead.
class QR
public:
QR( const char * text );
~QR();
* @fn bool QRCode::at(uint16_t x, uint16_t y);
* @brief Get the qr code value at a particular coordinate
* @param x x coordinate
* @param y y coordinate
* @return The value of the qr code at the supplied coordinate
bool at(uint16_t x, uint16_t y) const;
* @fn uint16_t QRCode::getWidth();
* @brief Get the width of the qr code
* @return The width
uint16_t getWidth() const;
* @fn uint16_t QRCode::getHeight();
* @brief Get the height of the qr code
* @return The height
uint16_t getHeight() const;
QRCode *qrcode;
uint8_t *qrcodeData;
#endif
QRCodeWidget.hpp
#ifndef QR_CODE_WIDGET_HPP
#define QR_CODE_WIDGET_HPP
#include <touchgfx/widgets/Widget.hpp>
#include <gui/model/QRCode.hpp>
* @class QRCodeWidget
* @brief A widget for displaying a QRCode
* The widget will be drawn in black and white.
* The values of the supplied QRCode will determine the appearance
* The widget can be scaled in order to display the qr code in an appropriate size
* @sa touchgfx::Widget
class QRCodeWidget : public touchgfx::Widget
public:
* @fn QRCodeWidget::QRCodeWidget();
* @brief Default constructor
QRCodeWidget();
* @fn virtual void QRCodeWidget::draw(const touchgfx::Rect& invalidatedArea) const;
* @brief Draw the part of the qr code that is inside the invalidated area
* @param invalidatedArea The region of this drawable that needs to be redrawn
* @sa touchgfx::Drawable
virtual void draw(const touchgfx::Rect& invalidatedArea) const;
* @fn virtual touchgfx::Rect QRCodeWidget::getSolidRect() const;
* @brief Report this widget as being completely solid
* @return The solid rect.
virtual touchgfx::Rect getSolidRect() const;
* @fn void QRCodeWidget::setQRCode(QRCode *code);
* @brief Set the qr code to display
void setQRCode(QR *code);
* @fn void QRCodeWidget::setScale(uint8_t s);
* @brief Set the scaling factor of the widget
void setScale(uint8_t s);
private:
void updateSize();
QR *code;
uint8_t scale;
#endif
‎2022-11-15 12:46 PM
I am trying it out. I included qrcode.c and qrcode.h from the https://github.com/ricmoo/QRCode library, and your QrCode.cpp, QrCode.hpp, QRCodeWidget.cpp and QRCodeWidget.hpp in my TouchGFX environment. I get below error. Am I missing any other files? Please advice.
‎2022-11-15 1:00 PM
Where did you place .h and .hpp files? Are they in project paths? Are .c and .cpp included in project?
These are regular compiler errors - check your project settings...​
‎2022-11-16 6:41 AM
I first put source and includes at TouchGFX\gui\src\widget\qrcode and TouchGFX\gui\include\gui\widget\qrcode respectively. That seems to be one folder level deep than necessary. So I moved to TouchGFX\gui\src\qrcode and TouchGFX\gui\include\gui\qrcode. Now TouchGFX sees them and tries to compile them when I click run simulator button.
Is this how you placed too? how did you tell TouchGFX to treat qrcode.c as a C file and not C++?
‎2023-08-11 2:33 AM
Hi, would you mind to share with me some many files, which they missing for me.
- Widget.cpp & .hpp
- Types.cpp & .hpp
- HAL.cpp & .hpp
Thanks in advanced
Mahdi
