Demos not shown on my Touchgfx
heyo
I had different versions of TouchGFX and when I downloaded 4.21.4 version it does not show demos. What can I do?
SofLit
You need to go to "Examples" menu:
PS: the latest version is V4.24
Check also your connection. It could be an issue with you internet connection.
PS: This is NOT an online support (https://ols.st.com) but a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
SofLit
GGODA
Hello @heyo ,
If your Example section is empty, it might be because your Designer is not able to connect to internet. Look at the top left if there is an exclamation mark.
If that is the case, you need to set up the proxy inside Designer and also set your location.
