Demo firmware doesnt work on STM32F769 Disco board
Kiran Nevaskar
I have purchased STM32F769 Disco Board. Post powering board from CN16 power LED turned on. Nothing appeared on LCD as described in Demo firmware. I reprogrammed FULL demo firmware STM32769I-DISCO_DEMO_V1.0.0_FULL.hex. LCD is struck at Blue logo. Nothing happens after that.
11 REPLIES 11
Please don't put the entire post in the Title - see:
https://community.st.com/s/article/How-to-Post
Limit the title to ~ 70 characters.
Imen.D
Hello @Kiran Nevaskar​ and welcome to the Community :)
I advise you to follow the instructions described in the readme file which is available under the same folder as Binaries under CubeF7 MCU package.
You can use the latest release either ST-Link Utility or STM32CubeProgrammer.
Imen
Imen
Hello Imen,
Thanks for your time.
I have went through the readme file and followed the instructions for flashing the full demo firmware. But it is not working. Post flashing I can only see Blue ST Logo.
I have downloaded binaries from
https://www.st.com/resource/en/compiled_demos/32f769idiscovery_demo.zip
If I flash STM32CubeDemo_STM32769I-DISCO_V1.4.0.hex binary from STemWin folder then I see the display as per attached image. It shows ST logo and and cpu specific details. But I cant see other icons showing options like audio or video player.
Not sure if received board has some defect or binaries has some problem.
Justin Zeppenfeld
Hello there,
the company i work for has recently bought the STM32F769 Discovery Board including the LCD-Screen.
After the first powerup the Screen showed only black and only the PWR-LED (LED6) turned on.
After downloading the Demofirmware from the official ST-Website and programming it via the STM32CubeProgrammer following the readme instructions given precisely, the Screen shows the ST-Logo and then stop there and wont show anything else.
did you found a solution for your described problem?
Justin
I think board has some manufacturing defect. I checked with technical team of distributor.
They sent me the replacement. Replacement worked perfectly.
To debug I built multiple binaries from STM32Cube7 software package but nothing worked. Looks like some bad component (may be audio related) on board prevents firmware init process.
Thanks.
Kiran
Hey Kiran,
thank you for your quick reply. Haven't thought about manufacturing issuses yet but the example projects given in Keil µVision (the toolchain we are working with) also just create random coloured pixels all over the screen. I'll do some debugging as you suggested.
Did you connect your supplier or ST-Microelectronics directly?
Justin
Hello Justin, I communicated with distributor.I dont what arrangements distributor has with ST. I am trying to say, demo firmware might be doing some init. During init, firmware is struck. I tried to run Audio using TouchGFX( STM32Cube7). It strucks at init audio in Audio app, it fails to play video as well. From that I had guess about some issue with Audio related hardware. Thanks. Regards, Kiran Sent from Yahoo Mail on Android On Wed, 24 Aug 2022 at 15:19, ST Community wrote: @media only screen and ( _filtered_a ) {#yiv3066576563 html {}#yiv3066576563 table.yiv3066576563container {width:100% !important;}#yiv3066576563 .yiv3066576563hidden-for-mobile {display:none !important;}#yiv3066576563 .yiv3066576563callToAction, #yiv3066576563 .yiv3066576563callToAction td, #yiv3066576563 .yiv3066576563footer {font-size:12px !important;}#yiv3066576563 .yiv3066576563button .yiv3066576563text {font-size:12px !important;}#yiv3066576563 .yiv3066576563defaultIndentation {width:10 !important;}#yiv3066576563 .yiv3066576563text {font-size:12px !important;}#yiv3066576563 a.yiv3066576563button {width:96 !important;}#yiv3066576563 a.yiv3066576563buttonWide {width:118 !important;}#yiv3066576563 a.yiv3066576563buttonAuto {padding-left:1em !important;padding-right:1em !important;}#yiv3066576563 a.yiv3066576563button, #yiv3066576563 a.yiv3066576563buttonWide, #yiv3066576563 a.yiv3066576563buttonAuto {min-height:23 !important;line-height:23px !important;border-radius:4px !important;}#yiv3066576563 td.yiv3066576563buttonWrapper {width:98 !important;min-height:23 !important;}#yiv3066576563 img {display:inline !important;}#yiv3066576563 .yiv3066576563circle {border-radius:50%;}#yiv3066576563 .yiv3066576563square {border-radius:10%;}}@media only screen and ( _filtered_a ) {#yiv3066576563 table.yiv3066576563container {width:600px !important;}}@media screen { _filtered {}}#yiv3066576563 a, #yiv3066576563 a:visited {color:#015BA7;text-decoration:none;}#yiv3066576563 img {display:block;}#yiv3066576563 .yiv3066576563preheader {display:none !important;}#yiv3066576563 table {border-collapse:collapse;}Hey Kiran, thank you for your quick reply. Haven't thought about manufacturing issuses yet but the example projects given in Keil µVision (the toolchain we are working with) also just create random coloured pixels all over the screen. I'll do some debugging as you suggested. Did you connect your supplier or ST-Microelectronics directly? Justin Hey Kiran,   thank you for your quick reply. Haven't thought about manufacturing issuses yet but the example projects given in Keil µVision (the toolchain we are working with) also just create random coloured pixels all over the screen. I'll do some debugging as you suggested.   Did you connect your supplier or ST-Microelectronics directly?   Justin Hello, I think board has some manufacturing defect.I checked with technical team of distributor. They sent me the replacement. Replacement worked perfectly. To debug I built multiple binaries from STM32Cube7 software package but nothing worked. Looks like some bad component (may be audio related) on board prevents firmware init process. Thanks. Regards, Kiran On Wed, 24 Aug 2022 at 14:48, ST Community wrote: @media only screen and ( _filtered_a ) {#yiv9657485219 html {}#yiv9657485219 table.yiv9657485219container {width:100% !important;}#yiv9657485219 .yiv9657485219hidden-for-mobile {display:none !important;}#yiv9657485219 .yiv9657485219callToAction, #yiv9657485219 .yiv9657485219callToAction td, #yiv9657485219 .yiv9657485219footer {font-size:12px !important;}#yiv9657485219 .yiv9657485219button .yiv9657485219text {font-size:12px !important;}#yiv9657485219 .yiv9657485219defaultIndentation {width:10 !important;}#yiv9657485219 .yiv9657485219text {font-size:12px !important;}#yiv9657485219 a.yiv9657485219button {width:96 !important;}#yiv9657485219 a.yiv9657485219buttonWide {width:118 !important;}#yiv9657485219 a.yiv9657485219buttonAuto {padding-left:1em !important;padding-right:1em !important;}#yiv9657485219 a.yiv9657485219button, #yiv9657485219 a.yiv9657485219buttonWide, #yiv9657485219 a.yiv9657485219buttonAuto {min-height:23 !important;line-height:23px !important;border-radius:4px !important;}#yiv9657485219 td.yiv9657485219buttonWrapper {width:98 !important;min-height:23 !important;}#yiv9657485219 img {display:inline !important;}#yiv9657485219 .yiv9657485219circle {border-radius:50%;}#yiv9657485219 .yiv9657485219square {border-radius:10%;}}@media only screen and ( _filtered_a ) {#yiv9657485219 table.yiv9657485219container {width:600px !important;}}@media screen { _filtered {}}#yiv9657485219 a, #yiv9657485219 a:visited {color:#015BA7;text-decoration:none;}#yiv9657485219 img {display:block;}#yiv9657485219 .yiv9657485219preheader {display:none !important;}#yiv9657485219 table {border-collapse:collapse;}Hello there, the company i work for has recently bought the STM32F769 Discovery Board including the LCD-Screen.After the first powerup the Screen showed only black and only the PWR-LED (LED6) turned on. After downloading the Demofirmware from the official ST-Website and programming it via the STM32CubeProgrammer following the readme instructions given precisely, the Screen shows the ST-Logo and then stop there and wont show anything else. did you found a solution for your described problem? Justin Hello there,   the company i work for has recently bought the STM32F769 Discovery Board including the LCD-Screen. After the first powerup the Screen showed only black and only the PWR-LED (LED6) turned on.   After downloading the Demofirmware from the official ST-Website and programming it via the STM32CubeProgrammer following the readme instructions given precisely, the Screen shows the ST-Logo and then stop there and wont show anything else.   did you found a solution for your described problem?   Justin Demo firmware doesnt work on STM32F769 Disco board I have purchased STM32F769 Disco Board. Post powering board from CN16 power LED turned on. Nothing appeared on LCD as described in Demo firmware. I reprogrammed FULL demo firmware STM32769I-DISCO_DEMO_V1.0.0_FULL.hex. LCD is struck at Blue logo. Nothing happens after that. Hello there,   the company i work for has recently bought the STM32F769 Discovery Board including the LCD-Screen. After the first powerup the Screen showed only black and only the PWR-LED (LED6) turned on.   After downloading the Demofirmware from the official ST-Website and programming it via the STM32CubeProgrammer following the readme instructions given precisely, the Screen shows the ST-Logo and then stop there and wont show anything else.   did you found a solution for your described problem?   Justin To change or turn off ST Community email, log in as kirannevaskar@yahoo.com.st. Are notifications about this post getting annoying? Reply to this email with the word " mute". STMicroelectronics N.V. |   | Hey Kiran,   thank you for your quick reply. Haven't thought about manufacturing issuses yet but the example projects given in Keil µVision (the toolchain we are working with) also just create random coloured pixels all over the screen. I'll do some debugging as you suggested.   Did you connect your supplier or ST-Microelectronics directly?   Justin To change or turn off ST Community email, log in as kirannevaskar@yahoo.com.st. Are notifications about this post getting annoying? Reply to this email with the word " mute". STMicroelectronics N.V.
S.Ma
Principal
Check the board user manual revision history chapter. BOM may have changed and the demo sw waa not updated?
