2019-10-01 02:55 PM
I have a product image that is not square,
how can I cut out the white background, within GFXdesigner?
2019-10-02 04:38 AM
You can't from within the designer, but you can use your favorite image editor to replace white with full transparency (magic wand + select white + delete?). This will for most editors introduce an alpha channel in your pixels and TouchGFX image converter will interpret this and generate pixel data for an ARGB8888 image.
/Martin
2019-10-02 04:38 AM
/Martin
2019-10-02 10:40 PM
will work with that, thanks
