2021-11-22 11:25 AM
I need a help or guide.
I have a problem with TouchGFX.
I updated Windows to Windows 11 recently.
I can't compile it after it is updated.
This is my error message.
Run Simulator
Generate
Done
Generate Assets
make -f simulator/gcc/Makefile assets -j8
Reading ./application.config
Done
Post Generate
touchgfx update_project --project-file=simulator/msvs/Application.vcxproj
Done
Compile
make -f simulator/gcc/Makefile -j8
Compiling gui/src/screen2_screen/Screen2View.cpp
Compiling gui/src/screen2_screen/Screen2Presenter.cpp
Compiling gui/src/screen1_screen/Screen1Presenter.cpp
0 [main] us 0 init_cheap: VirtualAlloc pointer is null, Win32 error 487
AllocationBase 0x0, BaseAddress 0x60EA0000, RegionSize 0x160000, State 0x10000
C:\TouchGFX\4.18.0\env\MinGW\msys\1.0\bin\mkdir.exe: *** Couldn't reserve space for cygwin's heap, Win32 error 0
make[2]: *** [build/MINGW32_NT-6.2/gui/src/screen2_screen/Screen2View.o] Error 1
generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/gui/src/screen2_screen/Screen2View.o' failed
make[2]: *** Waiting for unfinished jobs....
Compiling gui/src/screen1_screen/Screen1View.cpp
generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/gui/src/screen2_screen/Screen2Presenter.o' failed
make[2]: *** [build/MINGW32_NT-6.2/gui/src/screen2_screen/Screen2Presenter.o] Error 1
make[2]: *** [build/MINGW32_NT-6.2/gui/src/screen1_screen/Screen1Presenter.o] Error 1
generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/gui/src/screen1_screen/Screen1Presenter.o' failed
Compiling gui/src/model/Model.cpp
generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/gui/src/screen1_screen/Screen1View.o' failed
make[2]: *** [build/MINGW32_NT-6.2/gui/src/screen1_screen/Screen1View.o] Error 1
make[2]: *** [build/MINGW32_NT-6.2/gui/src/model/Model.o] Error 1
generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/gui/src/model/Model.o' failed
generated/simulator/gcc/Makefile:155: recipe for target 'generate_assets' failed
make[1]: *** [generate_assets] Error 2
simulator/gcc/Makefile:32: recipe for target 'all' failed
make: *** [all] Error 2
Failed
Failed
2021-11-24 09:47 AM
I tried to solve this problem by myself.
But I am not familiar with this kind of program.
Please let me know more detail.
What should I do to solve this problem?
2021-11-25 06:06 PM
Well, if this project is important to you, go back to WIn10 (uninstall Win11, take another Win10 machine) and be back to the business.
Win11 is new and things happen. Chinese wisdom says that change is evil; a billion of Chinese cannot be wrong.
Perhaps, try to enable win10 compatibility mode for C:\TouchGFX\4.18.0\env\MinGW\msys\1.0\bin\mkdir.exe
2021-11-29 08:48 AM
I tried in Windows 10, it is same.
I think that is not related with Windows 11.
2021-11-29 04:46 PM
Hmm. Could it be a buggy Cygwin mkdir.exe?
Try to play with it separately - does it fail outside of CubeIDE?
Is your computer managed by your company's IT and they recently installed or updated some "security" a-s-s-cover-ware?
2021-11-29 05:22 PM
Yes, I tried to mkdir in the Command window.
It works fine.
