Build fails to add stm32h7xx_hal_dcmi.c to make when DCMI added to CubeIDE project.
2022-07-05 2:50 AM
Adding DCMI to CM7 in MX (within cubeIDE) to a TouchGFX generated project against a 747_DISCO board causes stm32h7xx_hal_conf.h etc to be suitably updated, but stm32h7xx_hal_dcmi.c isn't added to build list.
Is there a manual way to add this to the project (or can ST fix this asap?)
DCMI
STM32CubeIDE
STM32H7 series
TouchGFX
2022-07-14 1:41 AM
Hi @Bruce ,
Normally, when you activate the DCMI in STM32CubeMx and generate the code, the stm32h7xx_hal_dcmi.c is automatically added in the STM32CubeIDE generated project.
Does the problem appear only when you use TouchGFX?
Could you please share a CubeMx configuration .ioc that can help to reproduce it so that I can investigate on my side?
A part from that, I advise you to follow this Application Note AN5020.
Kaouthar
