2020-02-10 11:17 PM
Dear all,
After I made a project with CubeMX 5.5 and checked a Graphics Application to use TouchGFX. Other all settings was good, I think. And then I did "GENERATE CODE" and I got ApplicationTemplate.touchgfx.part file. But this file cannot be open with TouchGFX 4.13.
Error Message is like "Object reference not set to an instance of an object".
( I translated it in English.)
Could you let me know about the reason and give me a right solution?
(The attached is a .part file.)
Thanks in advance.
2020-02-11 12:29 PM
I was able to open the .part file with TouchGFX 1.13.
Does it work if you open TouchGFX designer first and then click File->Open and open the .part file that way? Can you open any other .part files?
2020-02-11 5:00 PM
Thank you for your reply, Michael.
No,.. I tried to open it by the right steps that you mentioned but I failed to open it. I think the .part file extraced from CubeMX code generation is not perpect. Actually I filled some items by refering to other .part or touchgfx file and I could open it. Of course the final file is so different from the original one.
I will try other things and post some question if anything strange. And please let me know if there are other things that I have to know about this matters.
Thank you~!!
