Adapting Touchgfx codes to bigger LCD screen
Krautermann
Senior II
I am using Touchgfx for the STM32H745I Disco board. So far it has worked well with the default screen (4.3 inch). But I would like to use a bigger screen. So I will connect the STM32H745I board to a 9 inch screen.
Now my question is, will touchgfx codes still work on the bigger screen with larger resolution?
If not it is not going to work, what modification can I do to make it adapt to the larger 9 inch screen?
ktrofimo
Senior III
It depends on interface and resolution, not the size. I was successfully running 7" 1024x600 screen with RGB565 interface over LTDC bus. Refresh rate was about 30Hz because higher pixelclock was not supported by the display.
6 REPLIES 6
ktrofimo
Senior III
Thank you for your reply @ktrofimo​
The bigger screen has the same interface RGB888, but the resolution is however different. Bigger screen has 800x480 resolution in constrast to 480x272 from the default screen. Will that be a problem?
As for refresh rate of the bigger screen...I have no idea, it is not mention in the datasheet.
800x480 is not a problem - it should work. My screen have a little bigger resolution and it works.
RGB888 (24 bits) is a maximum bus width but you can easily lower it down to RGB565 (16 bits) with no serious visual degradation. With RGB565 bitmaps you can save 8 pins of the MCU and 30% of the memory size and bandwidth.
Regarding refresh rate: your datasheet should specify front and back porch as well as pixelclock. Knowing this you should be able to adjust LTDC and ​your refresh rate would be a pixelclock divided by total number of pixels (including FP and BP).
For recommended timings you will have
33,3 MHz / (40+800+40​)*(13+480+31) = 72,2 Hz
Douglas MILLER
This forum thread was marked by the moderator as needing a little more investigation, so a Support case was created in your name and will be handled off-line.
MM..1
Chief II
In your question miss important info what mcu on your disco? 128k version is more difficult...
_legacyfs_online_stmicro_images_0693W00000bk0MgQAI.pngbut primary code for new display is more better start with right steps new project as convert existed projects.
Hi, the board has STM32H745XIH6, so it's 2Mbytes and not 128KB.
