About LCD drive voltage
‎2020-12-20 9:59 PM
Is it possible to set the LCD drive voltage to 4.5VDC in STM32L073?
When using a VA liquid crystal panel an LCD, it is said that it cannot be driven by 3.6VDC.
LCD-LTDC
STM32L0 Series
‎2020-12-21 5:32 AM
The datasheet of the STM32L073, Section 6.3.21 gives some information on this: the internal LCD reference voltage can be set to a voltage between 2.6V and 3.55V.
It is not possible for the STM32L073 to generate a drive voltage of 4.5V.
Good luck!
/Peter
‎2020-12-21 5:32 AM
Good luck!
/Peter
‎2020-12-21 3:26 PM
Thank you very much.
It was very helpful.
