Dec 20, 2020 2:16 PM UTC
How to detect Release of item of scrolllist ?
I want work with scrolllist this way: touching and dragging -> scrolling the list of files, pressing (without drag) and releasing -> go to directory after releasing.
Question: how can i get Release event? Scrollist has onle 2 events - setItemSelectedCallback and setItemPressedCallback
MM..1
Dec 20, 2020 3:00 PM UTC
Try read this Workaround for swipe containers not swiping if dragged on a button within (st.com)
Or simpiy you need activate onclicklistener maybe not release
Dec 20, 2020 4:34 PM UTC
Problem.....
If I create more than 9 files - system halts when I scroll list DOWN.
The program halts during the execution of scrollList1UpdateItem() that is called for no apparent reason. is this normal? I don't update the elements, but for some reason when scrolling down scrollList1UpdateItem is called.
Should it be called while scrollin DOWN?
MM..1
Dec 20, 2020 4:42 PM UTC
scrollList1UpdateItem is called by system on every changes and need be writed as i show, reflect all values in itemIndex.
Please read how scrollist class work in reference ScrollList | TouchGFX Documentation
