STM32 Cyptolib with IAR 8.11
‎2017-04-13 12:11 AM
Posted on April 13, 2017 at 09:11
I've my application that uses the xCube CyptoLib 3.1.0 (STM32CryptographicV3.0.0_CM4_IAR_otnsc.a)with IAR compiler. Up to version 8.10 of the IAR compiler I never had any warning or error during the build of the project. Upgrading the IAR IDE to version 8.11 I have this error:
'Warning[Lt009]: Inconsistent wchar_t size crypto.o(STM32CryptographicV3.0.0_CM4_IAR_otnsc.a) has wchar_t size 16 bits '
Reading the release notes of the IAR 8.11 I found this:
IAR Information Center for ARM
Changed size of wchar_t in version 8.10 and 8.11
Object files following the ARM ABI has a runtime attribute indicating the size of wchar_t.
In EWARM version 7.80 and earlier, the size of wchar_t was 2 bytes wide and the runtime attribute was set accordingly.
For EWARM version 8.10, the size of wchar_t was 4 bytes wide but the value of the runtime attribute was not updated. Thus in 8.10 code is generated with 4 byte wide wchar_t but the object file is marked as if wchar_t is 2 bytes wide.
In EWARM version 8.11 wchar_t is 4 bytes wide and the runtime attribute is set accordingly.
Looking only at the wchar_t aspect this has the following implications:
All good except need to remove all parent title text for all comments.
Need to remove all parent title text for all comments.
- Combining object files built with 7.80 and 8.10 will not trigger any linker warning but if the application uses wchar_t, the behavior will be unpredictable.
- Combining object files built with 8.10 and 8.11 will trigger a linker warning but the application should work even if it uses wchar_t.
- Combining object files built with 7.80 and 8.11 will trigger a linker warning and if the application uses wchar_t, the behavior will be unpredictable.
Then, by this description, theCryptoLib 3.1.0 needs to be rebuilded with new version of the compiler to avoid unpredictable issues.
I planned a new release of the Crytolib compiled with IAR 8.11?
How I can solve this issue?
Cryptography
IAR
‎2018-06-01 1:18 AM
Hi all
Sorry for the delay to come back to you!
As committed a new
forhttp://www.st.com/en/embedded-software/x-cube-cryptolib.html
is now available to support the new IAR version : IAR Embedded workbench for ARM(EWARM) toolchain V8.22.Thank you very much for your interest on our STM32 products.
-Nesrine-
‎2017-04-18 12:14 AM
We are facing the same issue here but with the STemWin libraries found in the cube packages (using stm32f4cube 1.15.0), STemWin 532.
Peter.
‎2017-04-18 1:25 AM
I am checking this issue with our team & come back to you.Sorry for the inconvenience it may bring.
-Nesrine-
‎2017-04-26 2:55 AM
Hi Nesrine,
Any update on this one yet?
Many Thanks,
Peter.
‎2017-05-22 11:49 PM
Hi Nesrine,
can you estimate a date when the IAR 8.xx compatible release will be available?
At this moment I cannot migrate to IAR 8.xx due this library issue... but I need to do that as soon as possible.
Thank you.
Giuseppe
‎2017-05-23 3:59 AM
Hi
Cannarella.Giuseppe
,The issue is noted and will be fixed soon in coming firmware release.Sorry for the inconvenience it may bring.
-Nesrine-
‎2017-08-21 1:17 AM
Hi
ELMHIRI.Syrine
‌ is there already an 8.xx compatible release? I need to use the osxMotionFx library of the Cube package in IAR 8.- Mark as New
‎2017-08-29 8:23 AM
Hi
ELMHIRI.Syrine
‌ I have the same issue. When is the coming firmware release scheduled? Kind regards Jes Holm- Mark as New
‎2017-08-29 8:41 AM
What's IAR rationalization for wchar being 32-bit? Seems like a choice that would cause endless headaches.
‎2017-08-29 9:35 AM
Broader support for unicode characters I guess? The size of wchar_t is not defined in the C standard, so compilers are free to choose whatever size and/or signedness they prefer in order to fully support whatever character encodings they want to support, and generally this shouldn't be a cause of headache, well except for situations like this when there is a compiled blob without source code which you want to use, and your ABI is different. More reasons to use open source
GCC has the -fshort-wchar option which forces wchar_t to be 'short unsigned int' (2 bytes) on platforms where it has a different type. Maybe IAR has a similar option?
