hardware acceleration of mbedtls-2021 , - does ST have that?
2021-08-27 1:08 AM
Does ST offer an implementation of hardware acceleration of mbedtls-2021?
I found this:
STM32CubeL5\Projects\STM32L562E-DK\Applications\TFM\TFM_Appli\Secure\Src\ecdsa_alt.c
STM32CubeL5\Projects\STM32L562E-DK\Applications\TFM\TFM_Appli\Secure\Src\ecdsa_curves_alt.c
from https://github.com/STMicroelectronics/STM32CubeL5.git
This is excactly what I want (a bridge between mbedtls and the PKA_HAL driver), but it's for a 2019 version of mbedtls, and the mbedtls folks since broke the interface, so it doesn't compile. (and it doesn't look like an quick/easy fix)
Is there a newer version somewhere?
/Troels
- Labels:
STM32Cube MCU Packages
STM32L5 Series
2021-08-27 7:45 AM
Hi @TThom.2 ,
Our Expert was quick to provide an answer :)
Unfortunately, there is no plan to integrate new mbedtls version in the near future.
However, there is a suggested workaround to get rid of the compilation errors which is an ECC mbed TLS to PKA wrapper with recent mbed TLS version.
You find it attached and it will be interesting to keep us informed about the results on your side.
-Amel
2021-08-27 1:46 AM
Hi @TThom.2 ,
I'll share your request with our Experts & I'll keep you informed once I get the answer.
Internal ticket number: 112434 (PS: This is an internal tracking number and is not accessible or usable by customers).
-Amel
2021-08-27 1:57 AM
Thx , and sorry for the vague versions mentioned.
https://github.com/STMicroelectronics/STM32CubeL5.git uses mbedtls 2.16.2
I would like to use 2.26.x (or 2.27 or 3.0.0)
/Troels
2021-08-27 7:45 AM
Hi @TThom.2 ,
-Amel
2025-01-13 1:44 AM
Any updates about newer versions of mbedTLS? I am using 3.6.2. The provided wrapper is not longer suitable.
Greetings Hendrik
2025-01-22 11:30 AM
Hello @HendrikSchutter ,
The MBEDTLS 3.6.2 version will be supported in next delivery around Wk8 2025 on some STM32Cube.
Now I don't think STM32L5 is part of this delivery?
As far as I could see, there is no need to change the alternate files (wrapper) to make it work. I'll try check and come back to you
Best regards
Jocelyn
