F446RE Random Number Generator
‎2023-12-04 2:52 AM
I am Missing the Option Security>RNG in my the .ioc tool. Does the F446RE does not have a RNG?
i experience identical problems to Implementation of ECC on STM32f446 (Page 1) — wolfSSL — wolfSSL - Embedded SSL Library
- Labels:
STM32 Security
‎2023-12-04 5:55 AM
Well, this could be a copy'n'paste error, for which I would like to apologise. However, only the functions and parameters in the data sheet are relevant and guaranteed.
‎2023-12-04 2:53 AM
For my L452RE it looks like this:
‎2023-12-04 4:59 AM
Correct, in contrast to the STM32L452RE, the STM32F446 does not contain an RNG.
Does it answer your question?
/Peter
‎2023-12-04 5:37 AM
‎2023-12-04 5:55 AM
‎2023-12-04 6:18 AM
ok thank you. do you have any instuctions on how to use wolfssl without a rng. I am struggling to get rsa encryption to run. Thank you for your time.
‎2023-12-04 6:19 AM - edited ‎2023-12-04 6:24 AM
Apart from switching to an STM32 with RNG, no.
There are methods of generating a little randomness with a PRNG, by reading in the chip temperature or other simple approaches, but this is far away from a certified TRNG and may even be enough for a dice, but not for current encryption techniques.
‎2024-08-10 11:52 AM
i have the same problem did you found the solution ?
‎2024-08-10 1:05 PM
@fm1As mentioned before: choose an STM32 providing an RNG. If you have special requirements, you should create a new thread.
/Peter
