2018-07-26 01:42 AM
Starting from rm0090 up to rm433, the DMA_SxFCR register offset is given as
"Address offset: 0x24 + 0x24 × stream number"
The multiplicator is obvious wrong and should be 0x18.
2018-08-01 06:53 AM
Hi Uwe,
You are right: the formula should be like this: "Address offset: 0x24 + 0x18 × stream number".
Error is tracked internally and should be fixed in all relevant reference manuals.
Thanks.
-Amel
2018-08-01 06:53 AM
Hi Uwe,
Thanks.
-Amel
