work out poly
cjaya.2
Need a help to work out the formula. I cant get my head around with this to work out. its polynomial with numerator and denominator. what is the formula for this. Thank you
FLOAT_TYPE num_coeff[] = {-2.42580348918581e2l, 4.43575581447635e2l, -8.6570608699616e2l, 7.34933695653457e2l, -7.02396810482965e1l};
FLOAT_TYPE den_coeff[] = {1.e0l, -8.87493143817912e-1l, 2.75291524634514e0l, -3.88521936154463e-1l, 9.08722079164108e-3l};
FLOAT_TYPE num_poly = num_coeff[sizeof(num_coeff) / sizeof(num_coeff[0]) - 1];
FLOAT_TYPE den_poly = den_coeff[sizeof(den_coeff) / sizeof(den_coeff[0]) - 1];
for (int i = (sizeof(num_coeff) / sizeof(num_coeff[0]) - 2); i >= 0; --i)
   num_poly = num_poly * r + num_coeff[i];
for (int i = (sizeof(den_coeff) / sizeof(den_coeff[0]) - 2); i >= 0; --i)
  den_poly = den_poly * r + den_coeff[i]; } return (num_poly / den_poly);
5 REPLIES 5
num_poly(x) and den_poly(x) are each polynomials.
Result gives you num_poly(x) / den_poly(x).
Here, num_poly(x) = -2.42580348918581e2 + 4.43575581447635e2 * x - 8.6570608699616e2l * x^2 + 7.34933695653457e2 * x^3 - 7.02396810482965e1 * x^4
And den_poly(x) = 1.e0 - 8.87493143817912e-1 * x + 2.75291524634514e0 * x^2 - 3.88521936154463e-1 * x^3 + 9.08722079164108e-3l * x^4
Thank you for the reply and formula. When I did the excel calculation on this I get a different answer using the above formula. But When I complie it I get different answer. Why is that
These are the numbers for derived formula.
1.000
1.038
1.057
1.067
1.077
1.081
1.085
1.089
1.092
1.096
1.100
1.104
1.108
1.112
1.116
1.193
1.289
1.385
float res2temp(float r)
  int ni;
FLOAT_TYPE num_poly = num_coeff[sizeof(num_coeff) / sizeof(num_coeff[0]) - 1]; FLOAT_TYPE den_poly = den_coeff[sizeof(den_coeff) / sizeof(den_coeff[0]) - 1];
for (ni = (sizeof(num_coeff) / sizeof(num_coeff[0]) - 2); ni >= 0; --ni)
num_poly = num_poly * r + num_coeff[ni];
In this function I pass res2temp(6.e4f * adc_result / (1074547130368ll - (3ll * adc_result)))
The adc_result I putting are,
17909418.84,
18598931.46,
18944583.25,
19116513.67,
19288444.09,
19358290.82,
19426346.62,
19496193.35
,19564249.14
,19634095.87
,19702151.67
,19771998.4
,19840054.19
,19909900.92
,19977956.72
,21356981.97
,23081659
,24804545.09
its the same numbers when calculated adc_result, I mentioned above entering into excel but why excel gives different answer?
Is it not like this , because I am not getting write answer
Num Poly = -70.2397+ 734.9337x-865.7061x^2 + 443.5756x^3 - 242.58x^4
Den Poly = 0.009087 - 0.38852x + 2.752915x^2-0.88749x^3 + x^4
I edited my response. Perhaps you are looking at the un-edited version. Here is what I wrote:
