why should i write somethings in Defined symbols in IAR(?)
hossein hosseini
Posted on October 16, 2017 at 10:28
Hi;
i have a problem in my mind , that's i cant understand why should we
define
somethings like 'USE_STDPERIPH_DRIVER
STM32F103xE' in the Defined symbols box?!!
http://cttf.ir/wp-content/uploads/2017/06/IAR-Create-Project-jpg
and whydont we define this definition , our code give us many Error s ??
and if i want to see others Definition where can i found them??
so thanks.
iar defined-symbols
1 REPLY 1
Posted on October 16, 2017 at 10:44
It is just a standard method used by compilers to allow us to use the same set of read-only library source across a broad range of parts and code styles without requiring external file dependancies.
ST allows project specific defines in an stm32xyz_conf.h file which gets pulled if USE_STDPERIPH_DRIVER  is defined. A selection of other defines and include files get pulled in by that.
You could review the pre-processor output to see what the compiler is working with.
It is instructive to review the template projects and the meta data used by your chosen tool chain.
