where can I get STM32L431 QUADSPI memory controller reference design
JSanz.1
All do I need is how to initialize, erase, read and write (block and single data) the QUADSPI memory for STM32CubeIDE platform.
Thanks in advance
5 REPLIES 5
KevinA
I moved my 'Repository' from the default location to my USB3.2 12TB drive:
D:\STM32CubeIDE_1.2.0\Repository\STM32Cube_FW_L4_V1.15.1\Projects\32L496GDISCOVERY\Examples\QSPI
The code is for stm32L4xx
I'm doing a L432kc and L452ce, both use QSPI for storage.
For WHAT specific memory device, they are all a bit different, and have data sheets explaining the commands/expectations.
ST has some example code in the \Driver\BSP section of the repository, and L4 EVAL\DISCO boards. Check schematics as needed
Repository\STM32Cube_FW_L4_V1.15.1\Drivers\BSP\Components\n25q256a\n25q256a.h
Repository\STM32Cube_FW_L4_V1.15.1\Drivers\BSP\STM32L476G_EVAL\stm32l476g_eval_qspi.c
JSanz.1
Hi Kevin,
I'm trying to open the link but it not do anything
That's on his local hard drive, you'll need to look at the CubeL4 repository as you set it up on your system.​
Thanks, it's been so helpful
