What tool or script is used to generate the following code and how it's done? I need to generate similarly for STM32H7 series
AHuss.3
// STM32F407VG, STM32F407ZG, STM32F405RG
// DO NOT EDIT! Automatically generated!
static void stm32f40x_usart_create_objects(Object *obj, JSON_Object *svd,
       const char *name)
   STM32USARTState *state = STM32_USART_STATE(obj);
   JSON_Object *periph = svd_get_peripheral_by_name(svd, name);
   svd_add_peripheral_properties_and_children(obj, periph, svd);
   // Registers.
   state->u.f4.reg.sr = cm_object_get_child_by_name(obj, "SR");
   state->u.f4.reg.dr = cm_object_get_child_by_name(obj, "DR");
   state->u.f4.reg.brr = cm_object_get_child_by_name(obj, "BRR");
   state->u.f4.reg.cr1 = cm_object_get_child_by_name(obj, "CR1");
   state->u.f4.reg.cr2 = cm_object_get_child_by_name(obj, "CR2");
   state->u.f4.reg.cr3 = cm_object_get_child_by_name(obj, "CR3");
   state->u.f4.reg.gtpr = cm_object_get_child_by_name(obj, "GTPR");
   // SR bitfields.
   state->u.f4.fld.sr.pe = cm_object_get_child_by_name(state->u.f4.reg.sr,
           "PE");
   state->u.f4.fld.sr.fe = cm_object_get_child_by_name(state->u.f4.reg.sr,
           "FE");
   state->u.f4.fld.sr.nf = cm_object_get_child_by_name(state->u.f4.reg.sr,
           "NF");
   state->u.f4.fld.sr.ore = cm_object_get_child_by_name(state->u.f4.reg.sr,
           "ORE");
   state->u.f4.fld.sr.idle = cm_object_get_child_by_name(state->u.f4.reg.sr,
           "IDLE");
   state->u.f4.fld.sr.rxne = cm_object_get_child_by_name(state->u.f4.reg.sr,
           "RXNE");
   state->u.f4.fld.sr.tc = cm_object_get_child_by_name(state->u.f4.reg.sr,
           "TC");
   state->u.f4.fld.sr.txe = cm_object_get_child_by_name(state->u.f4.reg.sr,
           "TXE");
   state->u.f4.fld.sr.lbd = cm_object_get_child_by_name(state->u.f4.reg.sr,
           "LBD");
   state->u.f4.fld.sr.cts = cm_object_get_child_by_name(state->u.f4.reg.sr,
           "CTS");
   // GTPR bitfields.
   state->u.f4.fld.gtpr.psc = cm_object_get_child_by_name(state->u.f4.reg.gtpr,
           "PSC");
   state->u.f4.fld.gtpr.gt = cm_object_get_child_by_name(state->u.f4.reg.gtpr,
           "GT");
https://github.com/xpack/xsvd-js
5 REPLIES 5
Perhaps QEMU
AHuss.3
@Community member​
Thanks for the response.
Could you please let me know how it's done? I am a newbie to QEMU and I couldn't find any support for the same
Looks to be an SVD to JSON conversion tool, if it is not shared publicly then you'll need to talk with the developers
https://xpack.github.io/qemu-arm/
AHuss.3
@Community member​
Thank you! That was helpful
