What tool or script is used to generate the following code and how it's done? I need to generate similarly for STM32H7 series
‎2021-05-25 08:30 PM
// STM32F407VG, STM32F407ZG, STM32F405RG
// DO NOT EDIT! Automatically generated!
static void stm32f40x_usart_create_objects(Object *obj, JSON_Object *svd,
const char *name)
STM32USARTState *state = STM32_USART_STATE(obj);
JSON_Object *periph = svd_get_peripheral_by_name(svd, name);
svd_add_peripheral_properties_and_children(obj, periph, svd);
// Registers.
state->u.f4.reg.sr = cm_object_get_child_by_name(obj, "SR");
state->u.f4.reg.dr = cm_object_get_child_by_name(obj, "DR");
state->u.f4.reg.brr = cm_object_get_child_by_name(obj, "BRR");
state->u.f4.reg.cr1 = cm_object_get_child_by_name(obj, "CR1");
state->u.f4.reg.cr2 = cm_object_get_child_by_name(obj, "CR2");
state->u.f4.reg.cr3 = cm_object_get_child_by_name(obj, "CR3");
state->u.f4.reg.gtpr = cm_object_get_child_by_name(obj, "GTPR");
// SR bitfields.
state->u.f4.fld.sr.pe = cm_object_get_child_by_name(state->u.f4.reg.sr,
"PE");
state->u.f4.fld.sr.fe = cm_object_get_child_by_name(state->u.f4.reg.sr,
"FE");
state->u.f4.fld.sr.nf = cm_object_get_child_by_name(state->u.f4.reg.sr,
"NF");
state->u.f4.fld.sr.ore = cm_object_get_child_by_name(state->u.f4.reg.sr,
"ORE");
state->u.f4.fld.sr.idle = cm_object_get_child_by_name(state->u.f4.reg.sr,
"IDLE");
state->u.f4.fld.sr.rxne = cm_object_get_child_by_name(state->u.f4.reg.sr,
"RXNE");
state->u.f4.fld.sr.tc = cm_object_get_child_by_name(state->u.f4.reg.sr,
"TC");
state->u.f4.fld.sr.txe = cm_object_get_child_by_name(state->u.f4.reg.sr,
"TXE");
state->u.f4.fld.sr.lbd = cm_object_get_child_by_name(state->u.f4.reg.sr,
"LBD");
state->u.f4.fld.sr.cts = cm_object_get_child_by_name(state->u.f4.reg.sr,
"CTS");
// GTPR bitfields.
state->u.f4.fld.gtpr.psc = cm_object_get_child_by_name(state->u.f4.reg.gtpr,
"PSC");
state->u.f4.fld.gtpr.gt = cm_object_get_child_by_name(state->u.f4.reg.gtpr,
"GT");
STM32F4 Series
SVD
‎2021-05-25 09:02 PM
https://github.com/xpack/xsvd-js
‎2021-05-25 08:34 PM
Perhaps QEMU
‎2021-05-25 08:55 PM
@Community member​
Thanks for the response.
Could you please let me know how it's done? I am a newbie to QEMU and I couldn't find any support for the same
‎2021-05-25 09:00 PM
Looks to be an SVD to JSON conversion tool, if it is not shared publicly then you'll need to talk with the developers
https://xpack.github.io/qemu-arm/
‎2021-05-25 10:07 PM
@Community member​
Thank you! That was helpful
