What are the major changes in STM32F767BIT6 and STM32F777BIT6?
NJENN.1
Dear st team,
is STM32F767BIT6 code works in STM32F777BIT6?
CRYP and HASH IP enabled
Same die, same firmware
4 REPLIES 4
Imen.D
Hello @NJENN.1​ ,
You can compare your selected products using 'Cross selector' feature with ST-MCU-Finder tool (or in STM32CubeMX, for more details on how to use this functionality, please refer to dedicated section "4.2.4 Cross selector" in this manual UM1718).
I attached the result of my compare between STM32F767BITx and STM32F777BITx, hope this helps you.
The STM32CubeF7 MCU Package is used for all STM32F7 microcontrollers.
Imen
Imen
NJENN.1
HI,
thank you for your response. I have Stm CubeMx tool i got datasheets comarision.
Is their ant errata sheet for STM32F767BIT6 VS STM32F777BIT6.
Hi @NJENN.1​ ,
Here is the Errata sheet applies to the part numbers of STM32F76xxx and STM32F77xxx devices: ES0334 STM32F76xxx and STM32F77xxx device limitations 6.0
You will find all resources related to your device in the product page, in the Documentation panel:
Imen
Imen
