2022-07-04 10:26 PM
2022-07-05 01:36 AM
How do you expect this forum to help?
You need to take this up with your supplier, if you think it's an unacceptable substitute
2022-07-05 01:41 AM
Or are you just asking what's the difference between STM32F205RFT6 and STM32F205RET6 ?
The answer to that is in the datasheet:
2022-07-05 01:56 AM
Yes i know that, i tell about the marking code device
2022-07-05 01:57 AM
i have a E on the component but a R on the label
2022-07-05 02:15 AM
Again, if you think your supplier has sent you the wrong part, then you need to take that up with them.
Was it a reputable supplier...?
Or, if your not sure about the markings, and want confirmation of what you think you're seeing, then you need to post some good, clear, in-focus pictures of what you have - we can't see it any other way!
2022-09-15 11:27 AM
Hello GAzen.1,
Thank you for contacting STMicroelectronics. This forum thread was marked as needing more direct assistance.
An OLS support case was created in our Online Support Center (OLS) and you have been contacted directly regarding this inquiry.
For related inquiries, please submit a support case at www.st.com/ols
Kind Regards,
Christian
ST Support
2022-09-15 01:43 PM
If the user has not made their real name public, ST's employees should not do that either!
