variable phase shift between two PWM signals
‎2023-07-14 2:11 PM
I am trying to create to PWM outputs with a variable phase shift between them. They are of fixed frequency, 50% duty and exactly the same shape but with variable phase shift. I need to dynamically change the phase shift between them as a control parameter. I am OK with using two timers, but I cannot see how I can realize this.
STM32H7 Series
‎2023-07-14 3:47 PM
Simple trick is to use combined PWM mode. Take one timer, 4 channels would generate 2 PWM, where 1-st ch. defines start time and 2-nd channel - stop time of the first PWM, than 3 and 4 start/ stop second PWM. To shift just change CCR3 & CCR4 as a pair
‎2023-07-14 11:14 PM - edited ‎2023-07-14 11:15 PM
With 50% duty, an even simpler trick is to use two channels Output Compare in Toggle mode. Simply changing CCRx of one of them will change their mutual phase.
