Using OCTOSPI in Memory Mapped mode with an QuadSPI SRAM
CDan.1
Hi guys,
I am using an STM32L552ZET6 and I would like to extend the RAM using an external SRAM chip (23A1024-E/TS), that has an QuadSPI interface. I would like to know if I can use STM32L5 OCTOSPI interface in memory mapped mode with the above mentioned SRAM chip?
Thank you for your answer.
Cheles Dan
Amel NASRI
Hi @CDan.1​ ,
Yes it is possible to use OCTOSPI in order to interface a QuadSPI memory. This is the exact question answered in the article Does OctoSPI interface support QuadSPI memories?
-Amel
Amel NASRI
Hi @CDan.1​ ,
-Amel
For random parts, expect that you'll need to prototype and validate to your own satisfaction.
Check with the FAE's for the part(s) either at the manufacture, or distributor.
CDan.1
Thank you for your answers. My concern was regarding the Memory-mapped mode feature using QuadSPI SRAM. From what I read there should not be any problem. Thank you again for your support guys.
