Using Nucleo 429ZI and implanting a simple SPI code , There are no signals on the SCK Mosi pins when sending data on SPI1
RKore.1
I am using SPI1 as a Master full duplex , and checking in the Nucleo 429 zi
 PA5   ------> SPI1_SCK
There is no clock , I using a scope and testing PA5 pin on the Nucleo 429 zi
I attach the code , its very short code
Here is the link to the pin description
https://os.mbed.com/platforms/ST-Nucleo-F429ZI/
8 REPLIES 8
Pull the schematic, CAD Resources Tab of product page.
Trace the wire from IC pin to header(s)
Watch for solder bridges and zero-ohm resistor options
Check GPIO clocks, Check GPIO register settings.
Check AF mux mapping. Check GPIO toggles manually
RKore.1
Thanks Tesla
I can see the SPI1_SCK , the clk amplitude is about 0.5 volt , that is the reason i didn't see on the scope
Now i have to figure out why i don't see the MOSI
Do you have any suggestions
Yes, he had suggestions. Read his post again. Start with the first sentence, do what it suggests, and then proceed to next one.
RKore.1
Thanks ,
I will do what you suggest
I test the program on some new Nucleo 429 zi   that i bought from digikey ,
and in all of them it is the same result
I test the program it on SDI 1,2 and it is the same GPIO signals has 3 volt amplitude
Raz
RKore.1
Hi Tesla ,waclawek.jan
I did your recommended suggestions and they were OK , it was by multimeter and scope
  • Watch for solder bridges and zero-ohm resistor options --- OK as in the file attached
  • I did toggle one of the GPIO using software and it was working fine when measuring the pin - 0v --> 3.3 volt --> 0v
---Still have a problem ----
Is it OK that SDI SCK amplitude is 0.5Volt ?
Still do not see using a scope any signals on the MOSI pin
Mention that the pins are not connected to another board and i only measure by a scope each SDI pin
Raz
RKore.1
Hi Tesla
After searching , I found this link in the internet
https://github.com/stm32duino/Arduino_Core_STM32/issues/1112
I think it will help me
What is your suggestions ?
Raz
RKore.1
Hi Tesla
I think i found the Mosi signal , Its not PA_5 it is in in PB_5
Why it is written in the figure (Pin description) above PA_5 ad PB_5 are SPI1_MOSI
What is the difference ?
Raz
RKore.1
Thanks for your help Tesla
the problem is solved
